Understanding communication between hosts on the same subnet
I'm trying to get my head around when to use an irule with snat between hosts on the same subnet.
For example:
I have three hosts:
A = 10.10.10.1/24 (node on F5 / inside vlan)
B = 10.10.10.2/24 (node on F5 / inside vlan)
C = 10.10.10.3/24 (machine on the outside / outside vlan)
C wants to talk with A and B directly.
1/ In this example, do I need to configure a FORWARDING_VIP for C to be able to talk to A and B:
Set up FORWARDING_VIP for network 10.10.10.0/24
(Forwarding IP / All Ports / All Protocols)
Apply iRule to FORWARDING_VIP to snat hosts on the outside on the same subnet.
when LB_SELECTED { if {[IP::addr "[IP::client_addr]/24" equals "[LB::server addr]/24"]} { snat automap } }
Set up SELF_IP = 10.10.10.4/24
Set Default Gateway of A and B set to SELF_IP
2/ OR because they are all on the same segment, they should be able to ARP for each other's mac address and communicate at layer 2 so no routing involved???
We've been using option 1 in production for hosts on the same subnet to communicate with each other but now I'm not sure why it's needed (although it's working fine).
I would think hosts on the outside should be able to arp for hosts on the inside at layer 2 w/o any routing - so is the iRule needed? Yeah and I'm confused.
Thanks.
Andy
- Beinhard_8950
hmm, a little bit confusing this setup, but some clarifying is needed.Host A,B and C is on same subnet but is they on the same Vlan id? pretty important if we talk L2 and if the F5 is the router or you use VRF:s etc.
Or you maybe using routing domains or maybe "group vlan in the F5 to fix the above"?
However, if the F5 isn¨t the router for this vlan (or vlans) then you don´t need to use any snat or forward vip:s and so on. You only need SNAT when host C want to use the VIP for host A and B because of asymmetric routing.
But give some information about your setup.
B
