Icemanii_116694's avatar
Icemanii_116694
May 13, 2015
Solved
Unable to kill system connection using tmsh delete sys conn
I created a VS as below:
ltm virtual /Common/webserver_ISP2_http { destination /Common/71.1.1.3:80 ip-protocol tcp mask 255.255.255.255 persist { /Common/cookie { default yes } } pool /Common/WebPool2 profiles { /Common/http { } /Common/optimized-caching { } /Common/wan-optimized-compression { } } source 0.0.0.0/0 translate-address enabled translate-port disabled vlans { /Common/ISP2 } vlans-enabled }
I am seeing a lot of connections from my outgoing IP pinging to the public IP for this VS 71.1.1.3. Even after I disabled and deleted the VS I am still seeing a lot of connections being generated to this IP. I tried to kill the connections using the following:
tmsh delete sys conn cs-server-addr 71.1.1.3
when I am still seeing an increase in the connections when I use tmsh show sys conn cs-server-addr 71.1.1.3:
71.1.1.1:35980 71.1.1.3:80 71.1.1.1:58995 71.1.1.3:80 tcp 1 (tmm: 3) none 71.1.1.1:4972 71.1.1.3:80 71.1.1.1:40801 71.1.1.3:80 tcp 1 (tmm: 3) none Total records returned: 6686
I am unable to find any config related to the 71.1.1.3 VS after I deleted the VS. But I am still seeing connections. Any help will be much appreciated.
  • i think it will take a little bit time to kill all the connections.
    otherwise, if you want, you may try packet filter to reject connection to 71.1.1.3:80 or block it on upstream device.
    • Icemanii_116694's avatar
      Icemanii_116694
      Thanks for your help. I managed to isolate the connection to be generating from a pool of internal servers running some servers to the 71.1.1.3 IP. (This IP is a recycled IP) Once I created a FW policy to restrict off the servers to access the IP, all the connections dropped immediately.
      Icemanii_116694
