Jon_Strabala_46
Dec 16, 2009Two 'Default' Gateways for Production and Test
Hello,
I would like to set up an LTM cluster into two 'Default' Gateways one for "path" production and one "path" for testing.
GOAL configure F5/LTM/BIG-IP as follows:
Create two (2) virtual servers that act as default gateways one for testing and one for production traffic, each virtual server would have an fully independent iRULE. Only requests originating from 174.47.71.225 would go to the
"iruletest" VIP (a default gateway used for testing) all other traffic would go to the "default_gateway" VIP. See attached image for diagram.
How do I configure the F5 to do this (I really want two (2) independent paths - VIPs and iRULEs) ?
Note, the plan is to have the iRULEs will do modifications to the HTTP_RESPONSE.
Jon
- hoolio
This would be simple to do if you can dictate that the test clients access LTM from a different VLAN than the standard user. If that's possible, you could defined your two 0.0.0.0/0 VIPs on separate VLANs and use separate iRules.
If the test and production clients are on the same ingress VLAN, you could potentially use the virtual command (Click here) in an iRule to select a second test VIP for the specific clients you want to go to the test VIP. I haven't tried the virtual command with a forwarding network VIP though, so I'm not sure whether/how this will work.
Aaron - Jon_Strabala_46
I imagine in the latter case I could try a test like the following:
when RULE_INIT {
set ::g_prod_var 113
log local0. "RULE_INIT production_rule initialized: $::g_prod_var"
when CLIENT_ACCEPTED {
log local0. "CLIENT_ACCEPTED VirtualServer [virtual] from [IP::client_addr]:[TCP::client_port]: to [IP::local_addr]:[TCP::client_port]"
if { [IP::client_addr] == "174.47.71.225" } {
Send request to a new virtual server "test_irule", for iRULE testing
log local0. "HTTP_REQUEST switching from VirtualServer [virtual] to VirtualServer \"iruletest\""
virtual iruletest
log local0. "HTTP_REQUEST production_rule on VirtualServer [virtual]"
do something ....
However looking at the help on "virtual" I see that is says "In order to make this functionality work, one must precede the virtual command with an LB::reselect command if a pool member has already been selected" - how do I know if a pool member has been selected, does it hurt to blindly just stick the "LB:reselect" in (as you can tell I do not know too much about the F5 configuration).
Jon - hoolio
Hi Jon,
You don't need LB::reselect in CLIENT_ACCEPTED or HTTP_REQUEST as a load balancing decision hasn't been made yet.
For a standard TCP VIP with an HTTP profile, you'll see these events triggered
Request events:
CLIENT_ACCEPTED - clientside - triggered when LTM receives and accepts a connection from a client
HTTP_REQUEST - clientside - triggered when an HTTP profiles
HTTP_REQUEST_DATA - clientside - triggered if HTTP::collect was called in HTTP_REQUEST
LB_SELECTED - clientside - triggered when a node has been selected per the load balancing algorithm
SERVER_CONNECTED - serverside - triggered when a connection is established with the node
HTTP_REQUEST_SEND - serverside - triggered when LTM sends the HTTP request to the node
CLIENT_CLOSED - clientside - triggered when the client connection is closed
Response events:
HTTP_RESPONSE - serverside - triggered when LTM receives the HTTP response from the node
HTTP_RESPONSE_DATA - serverside - triggered if HTTP::collect was called in HTTP_RESPONSE
SERVER_CLOSED - serverside - triggered when the server connection is closed
iRule events wiki page
http://devcentral.f5.com/Wiki/default.aspx/iRules/events
iRule events (as part of IP:: questions)
http://devcentral.f5.com/Default.aspx?tabid=53&forumid=5&tpage=1&view=topic&postid=1018710235
Aaron
