sirad_85122
Apr 08, 2010Two Connection: close in HTTP response header.
Hi guys,
I have problem with HTTP::respond method. My I rule looks like:
set uri [HTTP::uri]
if { not ($uri starts_with "http") } {
set uri "http://$uri"
set method [HTTP::method]
set host [URI::host $uri]
set port [URI::port $uri]
if { [matchclass [string tolower $host] contains $::proxy_uri] } {
HTTP::respond 302 Location $uri "Connection" "close"
but, I'm receiving in response:
HTTP/1.0 302 Found
Connection: close
Server: BigIP
Connection: close
"Connection: close" header exists twice in HTTP header response. I'd like browser to reopen new TCP connection to server. When I use " HTTP::respond 302 Location $uri" get "Connection: Keep-Alive" in response.
I'm using BIGIP 9.3.1
Is it a bug or I'm doing something wrong?
Thanks for any advice.
Adam
- hoolio
Hi Adam,
Can you try this:HTTP::respond 302 Location $uri TCP::close
Aaron - J_C_13164Historic F5 AccountThere does appear to be some oddness with HTTP::respond and the headers in 9.3.1, though this works as expected in 9.4.8.
I would recommend using a TCP::respond in this case. :TCP::respond "HTTP/1.1 302 Found\r\nLocation: $uri\r\nConnection: close\r\nContent-Length: 0\r\n\r\n" - hoolio
This is actually described in SOL8960:
SOL8960: The HTTP::respond iRule command sends double Connection headers in the HTTP response
https://support.f5.com/kb/en-us/solutions/public/8000/900/sol8960.html
Aaron
