mishpan_70054
Mar 19, 2013transparent monitoring ldap/TACACS
Hi
I want to configure a monitor to LDAP/TACACS servers seating behind my ssl vpn box to mark the ssl vpn box up. So monitor traffic will flow somting like this
Ltm ----->ssl vpn box----> LDAP/TACACS server
I should be like transprant monitoring of LADAP/TACACS server. So this monitor should only mark the SSL vpn up if the LDAP/TACACS server is up.
- Ferg_104721
I think you would need to reserve your idea. Make your ldap/tacas server keep tunnel up. Use an ssl cert as auth, enable split tunneling with ACL's and the then maybe try health monitor, I would suggest ping. Have a cronjob in your server make sure tunnel is running or restart after reboot.
