Arindam_Majumde's avatar
Arindam_Majumde
Jul 08, 2019
transaction validation not working (PATCH with validationOnly:true)
I am getting errors from F5 while validating a transaction. here are the request and response pair.
Request for validation only (capture using fiddler)
PATCH https://172.17.235.162/mgmt/tm/transaction/1562600278455417 HTTP/1.1
Content-Type: application/json
X-F5-Auth-Token: YNVM7Q4UIP5RJUY6MX7B5WPYXY
Host: 172.17.235.162
Content-Length: 21
Expect: 100-continue
{"validateOnly":true}
Response for Big Ip fails (capture using fiddler)
HTTP/1.1 400 Bad Request
Date: 08 Jul 2019 15:40:30 UTC
Server: com.f5.rest.common.RestRequestSender
X-Frame-Options: SAMEORIGIN
Strict-Transport-Security: max-age=16070400; includeSubDomains
Pragma: no-cache
Cache-Control: no-store, no-cache, must-revalidate
Expires: -1
Content-Length: 120
Allow:
Local-Ip-From-Httpd: 172.17.235.162
X-Forwarded-Server: localhost.localdomain
X-Forwarded-Proto: http
X-Forwarded-Host: 172.17.235.162
X-Content-Type-Options: nosniff
X-XSS-Protection: 1; mode=block
Content-Security-Policy: default-src 'self' 'unsafe-inline' 'unsafe-eval'; img-src 'self' http://127.4.1.1 http://127.4.2.1
Connection: close
{"code":400,"message":"state must be VALIDATING in PUT request to commit the transaction.","errorStack":[],"apiError":2}
  • You are missing an attribute in your JSON payload:
      "validateOnly":true,
      "state":"VALIDATING"
  • Thanks Jason, do you also know how can I fetch (not save on device) entire configuration from big ip using REST? Save is not an option as in this scenario the users do not have access to the real device. Please let me know.
    • JRahm's avatar
      JRahm
      Icon for Admin rankAdmin
      Hmm, I don't think there is a direct way, but you could use the bash utility via REST to do a tmsh list, which would return thel raw response in the commandResults attribute
