Emad
Mar 24, 2013Traffic Load Handling.
we have too much traffic load from some specific client IP's and i want to make a separate pool for that clients. so that if request comes from their network that should be routed to separate pool.
What are the possiable ways to do that.
- Laudec_55181
Altostratus
You can use iRules for that:
rule myrule {
when CLIENT_ACCEPTED {
set vs "[IP::local_addr]:[TCP::local_port]"
if {[IP::addr [IP::client_addr] equals 172.28.19.0/24]}{
pool foo1
pool foo2
Or if you have many subnets, you can change the iRule to use a datagroup with the defined subnets in it.
