Traceroute and Telnet not working using IPs with route domain
HI All,
Is there any other to conduct traceroute and telnet command(use as troubleshooting with pool member connectivity) from F5. Example is traceroute 10.0.0.1%1.
Thanks! Ferdz
- THi
You can try to use rdexec -command
The rdexec utility allows you to perform a single command for the specified route domain instead of converting the IPv4 IP address argument to an IPv6 IP address argument before using it as an argument for the command. For example:
`rdexec []`There are several links in DevCentral on this, for example https://devcentral.f5.com/questions/ltm-traceroute-for-non-default-route-partition
