Ravager's avatar
Ravager
Feb 18, 2021
Basic telnet and traceroute testing
This might actually be a nice article for someone to write but I have some issues with telnet and traceroute on the f5.
I am assuming its possible to use these features like i do on a cisco switch by being able to specify a source ip and interface to go out on etc.
Let say i have the below with all GWs on .1
interface A
vlan2, 10.0.1.0/24 and vlan3 10.0.2.0/24
interface B
vlan 12, 10.1.1.0/24 and vlan 13 10.1.2.0/24
interface C MGMT
10.2.1.10 /24
how would i do a tracert from sources from each vlan using ip 10.x.x.6 as source (ie x being 10.0.1.6 10.0.2.6 10.1.1.6 10.1.2.6)
how would i do a tracert from the mgmt ip
how would i do a telnet on port say 1111 from each vlan using ip 10.x.x.6 as source
Reason i ask is we have a vary complicated network with multiple vendors administering various parts and while its easy to do these tests using a router sometimes its a router I dont have access to and it takes ages to request a 3rd party to do a the work. These tests are pretty much a standard for changing various Firewall rules around the network.
Cheers
  • as traceroute is just a linux tool the documentation gives some options, like to select an interface or source IP adres
    https://clouddocs.f5.com/cli/tmsh-reference/v14/modules/util/util-traceroute.html
    same with telnet
    https://devcentral.f5.com/s/question/0D51T00006uNZcz/test-access-sourcing-from-float
    have you tried those?
