Pankaj_70057
Jan 26, 2012To block some specific traffic from F5 for specific virtual directory
Here is the our requirement so if possible can you send me actual iRule to fulfill this requirement. Site: https://www.xyz.com/bac Allowed below host: 174.26.53.0/24 172.56.36.2 175.63.54.0/24 Block: all others Site: https://wwww.xyz.com Allowed for any So we require only filter for /bac virtual directory all other site running without any filter.
Thanks Pankaj
- hoolio
Hi Pankaj,
You can try to implement this type of logic in an iRule, but it may be simple to bypass:
http://devcentral.f5.com/Default.aspx?tabid=53&forumid=5&tpage=1&view=topic&postid=30900
That said, here is an example that could provide some protection. First, create an address data group containing the hosts and networks which can access /bac*. Then use an iRule like this which references a data group named allowed_hosts_dg:when HTTP_REQUEST { switch -glob [string tolower [HTTP::path]] { "/bac*" { if {not [class match [IP::client_addr] equals allowed_hosts_dg]}{ HTTP::respond 403 content {Blocked!} } } } }
Aaron - Pankaj_70057
I never create iRule this is first time so please can you send me acctual iRule with below example:
Allowed below host:
174.26.53.0/24
172.56.36.2
175.63.54.0/24
Block: all others
Allowed for any
So we require only filter for /bac virtual directory all other site running without any filter. - Pankaj_70057
Allowed below host:
174.26.53.0/24
172.56.36.2
175.63.54.0/24
Block: all others
Allowed for any
So we require only filter for /bac virtual directory all other site running without any filter. - hoolio
You can create the data group in the GUI under Local Traffic | iRules | Data group list | Create. Select a name of allowed_hosts_dg and a type of address. Then create the iRule using the code above and add that to the virtual server.
is this iRule works for both http and https? - Pankaj_70057
I am geeting error on iRule:
01070151:3: Rule [BAC_ALLOWD_IP_RULE] error:
line 5: [undefined procedure: class] [class match [IP::client_addr] equals BAC_ALLOWED_IP] - hoolio
Which LTM version are you on? You can check in the GUI under System | General Properties | Version. If you're on 9.4.4 or higher, you can use this
9.4.4 - 9.4.8when HTTP_REQUEST { Check the requested path set to lower case switch -glob [string tolower [HTTP::path]] { "/bac*" { Path started with /bac so check if client IP is in the allowed_hosts_dg data group if {not [matchclass [IP::client_addr] equals allowed_hosts_dg]}{ Send a 403 unauthorized response HTTP::respond 403 content {Blocked!} Or you could reset the TCP connection reject } } } }
9.4.3 and lowerwhen HTTP_REQUEST { Check the requested path set to lower case switch -glob [string tolower [HTTP::path]] { "/bac*" { Path started with /bac so check if client IP is in the allowed_hosts_dg data group if {not [matchclass [IP::client_addr] equals $::allowed_hosts_dg]}{ Send a 403 unauthorized response HTTP::respond 403 content {Blocked!} Or you could reset the TCP connection reject } } } }
System is running with :BIG-IP 9.4.6 Build 401.0 Final but still getting below error, i have created the DG with BAC_ALLOWED_IP.
01070151:3: Rule [BAC_ONLY_ALLOWED] error:
line 7: [undefined procedure: match] [match class [IP::client_addr] equals BAC_ALLOWED_IP] - hoolio
Sorry, it's matchclass not "match class". I edited the examples above with the correct command.
Aaron - Joe_Gorman_4645
Seeing this rule is a start to what I am currently needing but I have 4 folders that the Private_nets group need access to but external clients should not be allowed. Can I nest those into different rows for each directory?
Thanks in advance.
