uni's avatar
uni
Aug 21, 2007
Test for characters in a string
I want to test whether any of a set of characters exists within a string. I used the code below, but wonder if anyone can suggest a more efficient (and more elegant) method:
string match "*\[XYZ\]*" $var
  • hoolio's avatar
    hoolio
    I think scan would be faster and work assuming you can use a character class to define what you want to match.
    Click here
    [chars]
    The input substring consists of one or more characters in chars. The matching string is stored in the variable. If the first character between the brackets is a ] then it is treated as part of chars rather than the closing bracket for the set. If chars contains a sequence of the form a-b then any character between a and b (inclusive) will match. If the first or last character between the brackets is a -, then it is treated as part of chars rather than indicating a range.
    Aaron
  • Another option is to use the switch statement. So if you just want to see if "X", "Y", or "Z" are in a string, this would do the trick:
    switch -glob $var {
      "*A*" -
      "*B*" -
      "*C*" {
         match found
      default {
         no match found
    This will perform a bit faster than a comparable regular expression or if/elseif statements.
    -Joe
