James_Smith_299's avatar
James_Smith_299
Nov 22, 2016
TCPDump syntax to packet capture only initial TCP 3-way handshak
I'm needing to capture packets for a specific source device outputted to .pcap file. It sends sporadically into the BIGIP LTM so I'd like to leave a TCPDump running for 24 hours.
  • Source IP Address = 192.168.1.18
  • Destination port = 8000
Device file transfers large data set so I do not want to include that in my capture and risk running out of space. I simply want to capture TCP 3-way handshake during initial connection.
I need help with TCPDump syntax to accomplish this.
https://support.f5.com/kb/en-us/solutions/public/0000/400/sol411.html
  • Hamish's avatar
    Hamish
    Google is your friend here. tcpdump is a standard Unix/Linux utility. So a quick google will reveal (Among Others)
    How to capture TCP SYN, ACK and FIN packets with tcpdump
    And form there...
    To capture only TCP SYN packets:
     tcpdump -i  "tcp[tcpflags] & (tcp-syn) != 0"
    To capture only TCP ACK packets:
     tcpdump -i  "tcp[tcpflags] & (tcp-ack) != 0"
    To capture only TCP FIN packets:
     tcpdump -i  "tcp[tcpflags] & (tcp-fin) != 0"
    To capture only TCP SYN or ACK packets:
     tcpdump -i  "tcp[tcpflags] & (tcp-syn|tcp-ack) != 0"
    So your syntax would be something like...
    tcpdump -i 0.0 -nn -p -e "host 192.168.1.18 and port 8000 and tcp[tcpflags] & (tcp-syn|tcp-ack) != 0"
    H
