brianokelly_119's avatar
brianokelly_119
Nov 18, 2010
tcpdump raw packet capture
Does anyone know how to perform a raw packet capture using tcpdump? I have found multiple answers online but none seem to work. When I load the capture into wireshark I still see "Packet truncated during capture".
  • hoolio's avatar
    hoolio
    Hi Brian,
    The packets are being truncated because the default packet size capture is tiny. You can use -s 1500 or -s 0 on LTM to capture the full packets.
    SOL411: Overview of packet tracing with the tcpdump utility
    http://support.f5.com/kb/en-us/solutions/public/0000/400/sol411.html
    Capturing Packet Data
    The tcpdump utility provides an option which allows you to specify the amount of each packet to capture.
    You can use the -s (snarf/snaplen) option to specify the amount of each packet to capture. To capture the entire packet, use a value of 0 (zero). For example:
    tcpdump -s0 src host 172.16.101.20 and dst port 80
    Aaron
