Kirk_Bauer_1018's avatar
Kirk_Bauer_1018
Oct 31, 2008
TCP stream inspection problem
I'm running version 9.4.5 HF2.
I’m trying to use the following simple iRule to detect active versus passive FTP transfers. Unfortunately as soon as I apply this iRule to the virtual server the client sessions hang. All I get in the log is “client accepted”, so apparently the CLIENT_DATA event never triggers. I have also tried “TCP::collect 4” with no change in behavior.
when CLIENT_ACCEPTED {
log local0. "client accepted"
TCP::collect
when CLIENT_DATA {
log local0. "payload [TCP::payload]"
if { [TCP::payload] starts_with "PASV" } {
log local0. " ** passive transfer"
} elseif { [TCP::payload] starts_with "PORT" } {
log local0. " ** active transfer"
TCP::release
TCP::collect
Here is the virtual server:
virtual vip_ftp_in {
mirror enable
pool pool_ftp
destination 10.4.1.150:any
ip protocol tcp
vlans external enable
rules ftp_track
persist source_address_shared
Is there some special profile setting required for this?
  • Colin_Walker_12's avatar
    Colin_Walker_12
    Historic F5 Account
    The only reason the CLIENT_DATA event wouldn't fire is if the TCP::collect wasn't collecting the data required. Are you sending data through the connection once it occurs? Typing in a username or password or...something?
    Colin
