Ganesh_Ramamoor's avatar
Ganesh_Ramamoor
Jun 08, 2006
TCP iRule help
Thanks to you guys' help, I have this iRule:
when CLIENT_ACCEPTED {
TCP::collect
when CLIENT_DATA {
if { [TCP::payload] contains "xxx" } {
LB::detach
pool xxx
persist uie "[IP::client_addr]:[TCP::client_port]"
elseif { [TCP::payload] contains "yyy" } {
LB::detach
pool yyy
elseif { [TCP::payload] contains "zzz" } {
LB::detach
pool zzz
TCP::release
TCP::collect
This pretty much does what I'm looking for, the load balancing to the different types of pools and the persistence. But every time the client comes in with "yyy" the previous TCP connection is cleared and a new connection is established because of the LB::detach. And I need that LB::detach 'cause without that when the packets switch from "xxx" to "yyy" they would still be sent to pool xxx. Is there a way to keep the TCP connection up across the subsequent "yyy" packets?
Thanks in advance.
    Yes that worked, with one slight change of picking the pool only after a detach, as shown below. Thanks for your help.
    The LB::server and the LB::detach are per tcp connection, it appears, which is good, 'cause I was a little concerned about that. I tried this with 2/3 simultaneous clients and it seem to work fine.
    TCP::collect
    when CLIENT_DATA {
    set poolname "[LB::server pool]"
    if { $poolname ne "xxx" } {
    LB::detach
    pool xxx
    if { $poolname ne "yyy" } {
    LB::detach
    pool yyy
    TCP::release
    TCP::collect
