Ken_Wong_48678
Sep 11, 2006Historic F5 Account
tcl memory keep growing and LTM no response
One of our customer uses the following iRules to perform persistent and finds the tcl memory in statistics keep growing and caused the LTM no response.
Has anyone seen the symptoms? I think the iRule is quite common. Thanks in advance!
rule us_web_iRule {
when CLIENT_ACCEPTED {
set add_persist 1
when HTTP_RESPONSE {
if { [HTTP::cookie exists "JSESSIONID"] and $add_persist } {
persist add uie [HTTP::cookie "JSESSIONID"]
set add_persist 0
if { [HTTP::cookie exists "JSESSIONID"] } {
persist uie [HTTP::cookie "JSESSIONID"]
set jsess [findstr [HTTP::uri] "jsessionid" 11 ";"]
if { $jsess != "" } {
persist uie $jsess
Regards,
Ken (k.wong@f5.com)
- Colin_Walker_12Historic F5 AccountI don't see anything in that rule that would cause the memory consumption to continue increasing.
I'd probably fix the logic around the first if statement to be sure you're checking to see what the value of $add_persist is, not just that it exists...but I wouldn't think that would cause the behavior you're describing.
Have you tried adding some logging statements to ensure that things are firing the way you expect them to?
Colin
