System Times of Devices Do Not Match
I have two BIG-IP devices running 13.1.1 and noticed today in the UI that the times do not match. My passive/standby box is 6 seconds ahead. Looking at the configuration they are both using the same NTP server and all devices are in sync.
What would be causing this and how might I resolve it?
- youssef1
Cumulonimbus
did you verifying NTP peer server communications:
https://support.f5.com/csp/article/K10240
Please folow this kb to be sure that settings and communication worked fine:
Verifying the NTP daemon service-
Log in to tmsh by typing the following command: tmsh
To show the status of the NTP daemon, type the following command: show /sys service ntpd
Optional: If the NTP daemon service is not running, and you would like to start it, type the following command: start /sys service ntpd
Optional: If the NTP daemon requires a restart, type the following command: restart /sys service ntpd
To exit tmsh, type the following command: quit
Verifying the communication between the BIG-IP system and the NTP peer server- Log in to the BIG-IP system command line.
- To verify the NTP peer server communication, type the following command: ntpq -np
then follow the KB ...
regards
