rjordan's avatar
rjordan
15 years ago
Syslog severity not filtered
I just configured our LTM (running 9.4.6) to send syslogs to a remote server. At this point, I don't need very granular settings, so I just used bigpipe syslog remote server . I noticed that I'm getting a lot of syslogs at the information severity level. Most of them referencing "logger" or "crond". Based on the default severity settings, I wouldn't think I would be sending information level logs. Is there something else at play here?
[root@device:Active] config b syslog list all
syslog {
partition Common
authpriv from notice
authpriv to emerg
cron from warning
cron to emerg
daemon from notice
daemon to emerg
include none
kern from notice
kern to emerg
local ip none
mail from notice
mail to emerg
messages from notice
messages to warning
remote port 514
remote server 1.2.3.4
userlog from notice
userlog to emerg
  • George_Watkins_'s avatar
    George_Watkins_
    Historic F5 Account
    If you'd like to filter the log levels more granularly, there is an article for custom syslog configurations here on DevCentral: http://devcentral.f5.com/Default.aspx?tabid=63&articleType=ArticleView&articleId=155
    It is slightly dated, but should work fine for 9.4.6. Hope this helps,
    -George
