Mic_108850's avatar
Mic_108850
May 06, 2010
synchro issue between bot BIG-IP
Hi ,
when i start a synchro to peer i get this error:
Operation Status
Configsync Mode: Push
Transferring UCS to peer...
Installing UCS on peer...
OperationFailed exception:
   Primary error  : 16908289
   Secondary error: 0
   Error text     : Error installing configuration
Obtaining results of remote configuration installation...
Saving active configuration...
Current configuration backed up to /var/local/ucs/cs_backup.ucs.
Product : BIG-IP
Version : 10.1.0
Hostname: UCS   : am1.mydomain.org
          System: am2.mydomain.org
Installing --shared-- configuration on host am2.mydomain.org
Installing configuration...
Post-processing...
BIGpipe parsing error (/config/bigip.conf Line 333):
   012e0054:3: The braced list of attributes is not closed for 'rule'.
Reading configuration from /config/low_profile_base.conf.
Reading configuration from /defaults/config_base.conf.
Reading configuration from /config/bigip_sys.conf.
Reading configuration from /config/bigip_base.conf.
Reading configuration from /usr/share/monitors/base_monitors.conf.
Reading configuration from /config/profile_base.conf.
Reading configuration from /config/daemon.conf.
Reading configuration from /config/bigip.conf.
WARNING: There were one or more errors detected during installation.
         Check the error messages and take the proper actions if needed.
ERROR: UCS installation failed.
Operation aborted.
/tmp/configsync.spec: Error installing package
Config install aborted.
BIGpipe parsing error:
   01110001:3: Error running config install
Checking configuration on local system and peer system...
Peer's IP address: 10.10.10.3
Synchronizing Master Keys...
Could you help me?
