Keith_Richards_'s avatar
Keith_Richards_
Jun 22, 2008
switch for redirects
I am trying to redirect some URIs, and direct others to a pool. The following rule will not issue an HTTP redirect (TMOS 9.4.4)
switch -glob [string tolower [HTTP::uri] ] {
"/app1*" { HTTP::redirect "https://www.company.com/PRODapp1" }
"/app2*" { HTTP::redirect "https://www.company.com/COMPANY/" }
"/app3*" { pool pool_app3 }
"/COMPANY*" { pool pool_COMPANY }
"/*" { pool pool_COMPANY }
Any thoughts on what I'm getting wrong?
  • hoolio's avatar
    hoolio
    Hey Keith,
    Can you add logging to the rule? Does the matching work for a single HTTP request on a TCP connection? Also, make sure to set all the switch case URI's to lower case as you're setting the URI to lower case (like /company).
           "/app1*" {
              log local0. "[IP::client_addr]:[TCP::client_port]: [HTTP::uri] matched /app1"
           "/app2*" {
              log local0. "[IP::client_addr]:[TCP::client_port]: [HTTP::uri] matched /app2"
           "/app3*" {
              log local0. "[IP::client_addr]:[TCP::client_port]: [HTTP::uri] matched /app3"
              pool pool_app3
           "/company*" {
              log local0. "[IP::client_addr]:[TCP::client_port]: [HTTP::uri] matched /company"
              pool pool_COMPANY
           default {
              log local0. "[IP::client_addr]:[TCP::client_port]: [HTTP::uri] matched default"
              pool pool_COMPANY
    Aaron
