Dev_56330's avatar
Dev_56330
Icon for Cirrus rankCirrus
8 years ago
SWG Using Kerberos Fails on Some Workstations
I have SWG configured for user auth using NTLM and Kerberos. NTLM works fine though Kerberos only works on some workstations. When kerberos auth fails I receive an error "modules/Authentication/Kerberos/KerberosAuthModule.cpp: 'display_status_1()': 92: 4ec3a6d7 : GSS-API error gss_accept_sec_context: 70000 : No credentials were supplied, or the credentials were unavailable or inaccessible." These devices point to the same time source and time is in sync nearly to the second. I don't believe the key tab is an issue as I don't believe it would ever work. They are joined to the same domain and each have integrated windows authentication enabled. They reside in the same OU with no GPO's applied using the same user account. Anyone have experience with this error?
