Nicolas_MENOUX_'s avatar
Nicolas_MENOUX_
Apr 29, 2009
STREAM_MATCHED for regexp replace ?
I'm using an IRule to replace Http content coming from our web servers in order to change image relative path to absolute path as described below :
set host [HTTP::host]
when HTTP_RESPONSE {
if {[HTTP::status] == 200 and [HTTP::header "Content-Type"] contains "text"} {
if {$host ends_with ".xxxxx.com"}
STREAM::expression {@'/images/@'http://media.xxxxx.com/images/@}
STREAM::enable
} elseif {$host ends_with ".yyyyy.com"}
STREAM::expression {@'/images/@'http://media.yyyyy.com/images/@}
STREAM::enable
As you could see, I've to duplicate the STREAM::expression for each domain name as I do not know how to insert the $host variable into the replace string.
How could I use a single if statement to get a result like :
STREAM::expression {@'/images/@'http://media.$host.com/images/@}
STREAM::enable
DO I need to use STREAM_MATCHED context and if yes how to do it please. Thanks for your help,
Best Regards,
Nicolas
  • hoolio's avatar
    hoolio
    Hi Nicolas,
    The curly braces should prevent expansion of variables and interpretation of meta-characters (Click here). Also, due to a bug, you always ensure that double forward slashes (like those in http://) are enclosed in double quotes. And make sure to escape the periods or I think they'll be interpreted as a character repeat in a regex fashion:
    STREAM::expression "@'/images/@'http://media\.$host\.com/images/@"
    You only need to use STREAM_MATCHED if you want to log the match or modify the replacement strings.
    Aaron
  • thank aaron for your quick answer ;-)
    as stream_matched is quite new for me, what would be the basic script to insert the $host variable ? Thanks.
    Nicolas
  • hoolio's avatar
    hoolio
    Just what you had in your original post:
    You could add a check to see if the host value in the request was null and then use the VIP address or the public IP address if the VIP is an internal IP address:
         Check if the client used a host header
        if {[string length [HTTP::host]}[
            Use the VIP address instead
           set host [IP::local_addr]
    Aaron
  • mmm... I'm sorry I think and I'm sure I was not clear in my previous post :-) Thank you for your answer aaron, but if I want to re-use this $host variable into the stream replacement ? As you said, I could not use the $host within braces in the stream::expression, so could I do the replacement within the stream_matched event to replace the '/images/blablabla by 'http://media.$host.com/images/blablabla ? Do you have a sample to do that ? Stream::replace ? Thanks
  • hoolio's avatar
    hoolio
    Here the basic idea in one shot:
        if {[string length [HTTP::host]]}{
         Check if the response was a 200 and text
           STREAM::enable
           STREAM::disable
    Note that the double quotes allow variable expansion to take place and work around a bug in the LTM code with unquoted //'s.
    Aaron
