adrien_mistrett's avatar
adrien_mistrett
Jul 21, 2005
strange values with ProfileClientSSL get_all_statitics
I've wrote a little prog to get the current ssl connection number for each ssl profile
The fourth ssl profile return really a strange value, as there in fact, between 0 an 100 connections to this ssl_profile
Here is the output of my little prog
Statistics collected 21/7/2005 15:12:21
anon_ssl_profile ssl current connections
* high : 0
* low : 16
* high : 0
* low : 0
* high : 0
* low : 0
* high : -1
* low : -39
* high : 0
* low : 101
* high : 0
* low : 71
Here is the Prog:!/usr/bin/python
V1.0 Adrien Mistretta
import sys
import os
import time
import SOAPpy
import string
import StringIO
User="user"
Pwd="password"
BigIp="hostname"
anon=1
statistics_list=[]
Location="https://"+User+":"+Pwd+"@"+BigIp+"/iControl/iControlPortal.cgi"
server = SOAPpy.SOAPProxy(Location, namespace = "urn:iControl:LocalLB/ProfileClientSSL")
try:
all_statistics=server.get_all_statistics()
except:
print "ERROR: server.get_all_statitics FAILED !!!"
statistics_list=all_statistics.statistics
when=all_statistics.time_stamp
print "Statistics collected "+str(when.day)+"/"+str(when.month)+"/"+str(when.year)+" "+str(when.hour)+":"+str(when.minute)+":"+str(when.second)
for stat in statistics_list:
if ( stat.profile_name != "clientssl" ):
name=stat.profile_name
for i in stat.statistics:
if ( i.type == "STATISTIC_SSL_COMMON_CURRENT_CONNECTIONS" ):
if (anon==1):
name="anon_ssl_profile"
print name+" ssl current connections"
print " * high : ",i.value.high
print " * low : ",i.value.low
  • Loc_Pham_101863's avatar
    Loc_Pham_101863
    Historic F5 Account
    What does the particular client SSL profile that reports "bogus" stats look like? From your snippet of code, it doesn't look like it's one of our default profiles, so if you can provide an example of your profile configuration as well of the virtual server using this profile, we'll see if we can reproduce the error condition here.
    Regards,
    Loc
  • hello, here is the conf
    profile clientssl mysslcert {
    defaults from clientssl
    key "blah.key"
    cert "blah.crt"
    chain "intermediate-ca.crt"
    profile http mail-http {
    defaults from http
    oneconnect transformations disable
    header insert "X-ProxySSL-For: [IP::client_addr]"
    pool mail-http {
    lb method member least conn
    monitor all http
    member 172.16.0.45:http
    member 172.16.0.46:http
    member 172.16.0.47:http
    virtual https-service {
    destination 10.0.0.10:https
    snat automap
    ip protocol tcp
    profile mail-http oneconnect mysslcert tcp
    persist ssl
    pool mail-http
    vlans cs enable
  • hello,
    I got some news about this problem, values are ok after a reboot of the bigip, but start to be inconsistent after a few days of uptime.
    It look like a memory corruption, or something like that.
    Adrien
