Techgeeeg_28888
Jul 05, 2012Strange problem Root password field not showing in the GUI
Hi Everyone,
I am really facing a very strange problem. I have on my LTM box TMOS 10.x.x and also 11.1 in the GUI of 10.x.x under platform I can see both the fields Admin as well as root password which is normal. But in TMOS 11.1 I don't see any the root password field it only shows the Admin password field. Does anyone come across this problem or is it some know issue or bug. I will be really thankful for the support.
Regards,
- nitass
Employee
are you running appliance mode?
sol12815: Overview of Appliance mode
http://support.f5.com/kb/en-us/solutions/public/12000/800/sol12815.html - Techgeeeg
Hi Nitass,
Thanks for your reply I just checked my license and yes the unit is running in Appliance mode only with only TMSH access. Now if I want to have root level access is this only possible after requesting a change in license or else there is some other way.
Regards, - nitass
Employee
Now if I want to have root level access is this only possible after requesting a change in license or else there is some other way. i understand you have to do clean install and obtain a new license (without appliance mode). - Techgeeeg
Ok Thanks.... I will check this out
