Thomas_Lam's avatar
Thomas_Lam
Mar 13, 2016
starts_with Not working
Hi there,
the target url is "https://portal.abc.com/store/register.aspx?lang=en"
I tried to redirect the page when hit the above url with below irule, but it didn't work.
when HTTP_REQUEST { if { [string tolower [HTTP::uri]] starts_with "/store/register.aspx" } {
HTTP::respond 200 content "It works"
However, if I tried below by replacing "starts_with" to "contains", it somehow works, but this is not I want.
when HTTP_REQUEST { if { [string tolower [HTTP::uri]] contains "register.aspx" } {
My F5 version is "BIG-IP 10.2.2 Build 852.0 Hotfix HF1".
Thanks.
  • Have you tried adding some logging, so you can see what [HTTP::uri] is? Have you tried adding some logging, so you can see what [HTTP::uri] is? when HTTP_REQUEST { if { [string tolower [HTTP::uri]] contains "register.aspx" } { log local0. "HTTP::URI: [HTTP::uri]" HTTP::respond 200 content "It works" } } This will log on /var/log/ltm
  • Thanks John. I have added the logging, and it shows as below. It seems the HTTP::uri is returned as expected, but somehow I'm not sure if the "starts_with" is not working properly, or somewhere I missed out. Thanks.
    Rule Testing_Block : HTTP::URI: /store/register.aspx?lang=en
