Khoa_53278
Jun 04, 2009Standby F5 processes restart when synchronising with active unit?
Hi all,
We have 2 F5 LTM units running active/standby. When we add some config in the active unit and perform sysching between 2 units, our SNMP Monitoring tool indicated that the standby unit rebooted. From uptime of the standby unit, it said that it up for more than 50 days and the messages liog show that some processes restarted at the same time of synchronization:
In the log of ltm:
Jun 3 15:54:28 SGDC2SS1LB02 bigpipe: Begin config install operation: /var/local/ucs/__sync_remote__.ucs
Jun 3 15:54:28 SGDC2SS1LB02 mcpd[1117]: 01070410:5: Removed subscription with subscriber id Subsnmpd_Subscriber
Jun 3 15:54:30 SGDC2SS1LB02 mcpd[1117]: 01070465:4: DB changed: failover.nettimeoutsec, configsync needed
Jun 3 15:54:30 SGDC2SS1LB02 mcpd[1117]: 01070465:4: DB changed: failover.netretrylimit, configsync needed
In the boot log:
Jun 3 15:54:30 SGDC2SS1LB02 ntpd: ntpd shutdown succeeded
Jun 3 15:54:30 SGDC2SS1LB02 ntpd: ntpd startup succeeded
And daemon log:
Jun 3 15:54:30 SGDC2SS1LB02 ntpd[5400]: ntpd exiting on signal 15
Jun 3 15:54:30 SGDC2SS1LB02 ntpd[17717]: ntpd [email protected] Mon Oct 15 12:16:59 PDT 2007 (1)
Jun 3 15:54:30 SGDC2SS1LB02 ntpd[17717]: kernel time discipline status 0040
Jun 3 15:54:33 SGDC2SS1LB02 named[17818]: starting BIND 9.3.5-P1 -f -t /var/named -u named -c /config/named.conf
Jun 3 15:54:33 SGDC2SS1LB02 named[17818]: the working directory is not writable
Jun 3 15:54:33 SGDC2SS1LB02 named[17818]: command channel listening on 127.0.0.1953
Jun 3 15:54:39 SGDC2SS1LB02 subsnmpd[17845]: Connect to master agent successfully.
Jun 3 15:54:42 SGDC2SS1LB02 rmonsnmpd[17852]: Connect to master agent successfully.
Is this normal when sysnching the configuration and the standby box restart the processes?
Thanks,
Khoa
- The_Bhattman
Hi Khoa.
The logs look normal during a active to standby unit. However, if the SNMP Uptime that you are monitoring is coming back to zero then it's possible you are running a version with a bug in it or you are monitoring the wrong Uptime element. What version are you running?
Thanks,
CB
