standard - f5 traffic flow
i hv following questions...
1.) when user access to f5, virtual server will direct traffic to the pool members servers, what is the traffic use by external or internal access to f5 device? is it using TLS or SSL?
currently, i can see i am using http:// to access the virtual server
2.) any one has good diagram for sharing the traffic flow?
3.) i can see traffic monitor for http request and ssl only.. not sure if TLS exist?
4.) for configuration utility access using web browser https://f5.local.com wonder where to check https already enabled?
thanks for your reply :)
