vinocalk's avatar
vinocalk
Dec 24, 2013
SSO for Storefront and AAC in same domain
We have one domain (say www.myurl.com) but different backend services for different URL's. www.myurl.com/location1 takes you to a Storefront server and www.myurl.com/location2 takes you to a legacy Citrix AAC logon page (soon to be decommed but needed in the short term).
I have managed to get SSO working for both Storefront (form based) and AAC (forms client-initated) in isolation but I cannot work out how to have them both working at the same time. I have played with multi-domain SSO but had no joy there. Alternatively I then tried adding a second form to my client-initiated set-up for Storefront but could not get that working.
Would really appreciate it if someone could point me in the right direction with this please!
Is multi-domain SSO appropriate here? (given that I am actually only using one domain) Can you use multiple forms with client-initated SSO for this kind of thing? Is it possible to get Storefront working with client-initiated SSO?
Many thanks and Happy Xmas everyone!
  • Using WEBSSO::select fixed this. But I ran into the bug where by you cannot select a client-initiated form using WEBSSO::select (still not fixed in 11.4.1 HF1 build 625)
    I spent ages playing with my client-initiated form as the default SSO object (defined in the access profile) and using WEBSSO::select to select my forms-based SSO object but could not get it to work (Kevin Stuart has got this working though - https://devcentral.f5.com/questions?pid=28) I think in my case this is something to do with the way Storefronts logon page works. It sends a lot of POST's whilst generating the logon page and I found that my browser would get stuck in a loop re-submitting the POST for the URI that was being matched by my SS)::select iRule.
    I eventually found the workaround to the WEBSSO::select bug and this worked for me (ie. I made the forms based SSO the default and used to WEBSSO::select to select by client-initiated SSO as described below) -
    399696Selecting an SSO configuration with WEBSSO::select does not work for form-based client initiated and SAML configurations. You can work around the problem by using a variable to assign the configuration object name. For example: set sso_config /Common/SAML-config WEBSSO::select $sso_config unset sso_config
