DenisGR_21754's avatar
Nov 08, 2017
Solved
SSO between APM and citrix StoreFront not working
I'm facing an SSO issue to use my big ip 12.1.2 with my Citrix's storefront 3.X (I want to keep them)
I have used this document and used iapp ";.
When user try connect to my Citrix farm through the big ip he's passing APM logon page without any problem(AD auth only) but he needs to authenticate a second time in Citrix StoreFront to access applications.
I have tried following solution without any success.
Please help Thx.
  • The problem seems to be related to my version of Big IP 12.1.2.0.283.249. Get back to 12.1.2.0.0.249 and SSO seems to be working now.
    • DenisGR_21754's avatar
      DenisGR_21754
      Icon for Cirrus rankCirrus
      If you don't want to downgrade you box, you can install HF2 it'll resolve Citrix's SSO issue
