Dev_56330's avatar
Dev_56330
Icon for Cirrus rankCirrus
Jan 17, 2018
SSL renegotiation on the management interface
Does anyone have details on how to troubleshoot SSL renegotiation issues on the management interface while trying to implement clientcert - ldap auth for remote user authentication? It seems you are unable to run SSLdump on the management vlan and I am getting errors on wireshark when trying to decrypt that I am unable to do so using ECDH_RSA. Thoughts? Suggestions?
  • Hello Dev,
    Can you give us details your problem. what is your main problem? basically you have a problem with user authentication for management Access. More for managmeent authentication you use Remote auth (LDAP). And you encounter authentication problem, that's why you wanted to sniff the traffic? that's Right...
    Regards
