Kristof_Goossen
Sep 21, 2010SSL renegotiate issue in IE
I am using an iRule to trigger client cert authentication on specific URL's. The idea is to invalidate a current (single side authenticated SSL session) and renegotiate a mutual SSL session. This is working fine for firefox, but gives some issues in IE (tested in IE7 and IE8). Sometimes the setup is working as expected, but sometimes, the browser cannot connect after renegotiating the session.
When it works, the session is invalidated, and the browser returns and negotiates a mutual SSL session (we see a CLIENT_CONNECT event, and subsequent events in the logging). However, when the setup fails, a locally generated page is shown in the browser (see attachment) and it seems the SSL session cannot be set up. The client seems not to come back from the BigIP point of view.
The code in the iRule looks like this:
Check if the request is to a page which requires a client SSL certificate
if {[matchclass [HTTP::path] starts_with $::triggerURLs]}{
Save the requested URI for logging in subsequent events
set requested_uri [HTTP::uri]
Track that this is a request for a restricted URI
set need_cert 1
if {$loglevel > 0}{log local0.info "$log_prefix Request to restricted path: [HTTP::path]. \$need_cert: $need_cert"}
if {$loglevel > 2} {log local0.info "$log_prefix Checking Session - $sslSessionID"}
Hold the HTTP request until the SSL re-negotioation is complete
if {$loglevel > 5}{log local0.info "$log_prefix HTTP::COLLECT - [HTTP::method]"}
HTTP::collect
Force renegotiation with client certificate
SSL::session invalidate
SSL::authenticate once
SSL::authenticate depth 9
SSL::cert mode request
SSL::renegotiate
if {$loglevel > 0}{log local0.info "$log_prefix Restricted path ([HTTP::uri]). Requesting client Cert."}
A login page posts to a URL in the triggerURLs list, and initiates the authentication. When I disable the CSS on that login page, the issue cannot be reproduced. (Strange behaviour that I don't understand). I tried to limit simultane connections for IE to 1, but it did not solve the issue.
I built a similar environment (single side SSL page that posts to a mutual SSL page) with apache, but in that setup I could not reproduce the issue.
Any help would be much appreciated!
