Albert__Tase_70
Mar 19, 2008ssl persistance and base on uri contents
Is there a way to use irule like this
when https request comes in to vip if the request contains x in the uri use ssl persit profile and use pool x
else use pool y
thanks
- Nicolas_Menant
Employee
You can do this by making the BIGIP be the SSL termination.
Then in the HTTP request event you can do the following:
if { [HTTP::uri] contains "x" } {
persist ssl [SSL::sessionid] 1800
where 1800 here is the timeout
The default pool of your vs should be pool y
HTH - The_Bhattman
Another alternative code would look like the following:when HTTP_REQUEST { switch [HTTP::uri] { "x" { persist ssl [SSL::sessionid] 1800 pool poolx } "y" { pool pooly } } }
orwhen HTTP_REQUEST { if { [HTTP::uri] eq "x" } { persist ssl [SSL::sessionid] 1800 pool poolx } else { pool Pooly } }
thanks
/CB - Nicolas_Menant
Employee
[ERROR FIXED] - The_Bhattman
It was a cut and past error I just fixed.
/CB - Albert__Tase_70
I tired the following and can't seem to get the syntax right
pool poolx
pool Pooly
line 3: [wrong args] - Nicolas_Menant
Employee
try this one:
persist uie [SSL::sessionid] 1800
pool poolx
pool Pooly
} - Nicolas_Menant
Employee
yes it's normal PROFILE::persist command is to retrieve data, not set them up.
As i said try those iRules:
try this one (it is uie instead of ssl and it's normal^^):
pool poolx
pool Pooly
or this one:
persist ssl
pool poolx
pool Pooly
be careful in those iRules, the uri must contains x. eq "x" is not a good idea since a URI will at least start with "/" so it will never match simply x - The_Bhattman
According to the wiki PROFILE::persist doesn't set the persistance but simply returns a value after it is selected
Here is another approach
Create SSL Persistenace and assign it to the VIP then in your irulewhen HTTP_REQUEST { if { [HTTP::uri] eq "/x" } { pool poolx } else { persist none pool pooly } }
Hope that helps
Employee
As i said HTTP::uri will never be equal to X since it will start by a "/"
so if you wanna try CB method i'd advise to do a eq "/x" or a contains "x"
pool poolx
persist none
pool pooly
} - Albert__Tase_70
ok when i use the last post it still not working
if I use the following
if { ([HTTP::uri] contains "x")}{
HTTP::redirect "https://x.x.x.x:8443/x/"
pool y
however they do not want to have the redirect
in the above the redirect sends it to the virtual with the same pool assigned as the below and I get whats expected
however the redirect seems to affect the app why can't I when it matches send it to the pool that has the servers in it that the vip has that when I redirect to it gives me the expected results.
if { [HTTP::uri] contains "x"}{
persist uie [SSL::sessionid] 1500
pool x
pool y
thanks
Al
