KhubaibArshad's avatar
KhubaibArshad
Nov 27, 2019
SSL PassThrough Configuration
I have an web based application running on three different servers, I want to balance the load using round Robbin technique, the ip address of those servers are 10.10.10.71 72 & 73. They are allowed to accept only https protocol. The Vip is 10.10.10.70. The requirement is to configure SSL pass through on the BIG-IP 3600 f5 because we don't have an ssl certificate. Each server responds when i browse them by their actual IP. But when i browse the VIP its not working. I guess its because of the SSL pass through. Can someone help to configure SSL Pass Through because i a newbie to F5.
  • Hi
    To enable SSL Pass Through, dont configure any SSL profiles on your VIP or any Layer 7 profiles. You can only configure upto Layer 4 with Pass-Thru.
    If you need your F5 to be a TCP proxy then you can leave the VIP type as Standard but if there is no requirement for this then you could use the Performance Layer 4 VIP type.
    Also, as your VIP is on the same subnet as your servers, I'm guessing that you will need to enable SNAT to ensure the return path goes to your F5 rather than the servers default gateway (unless your F5 is the default gateway)
    Hope this helps
  • Hi @iaine
    I successfully enabled the SSL pass through and SNAT, but there is an issue, it works for a very short time and after that I get the same error ERR_CONNECTION_REFUSED by the client. When I update SNat with the same configuration it works again and after that it gives the same error. Can you please tell what is happening here?
    • Ahmed_Galal's avatar
      Ahmed_Galal
      did you cofigure monitor for backend servers. i think that this might be related to a one of backend servers issue because there is no configuration in SSL passthrough you just dont configure profiles and configure backend servers with port 443.
      • KhubaibArshad's avatar
        KhubaibArshad
        Hi Ahmed,
        No I am not using the Health Monitors for the back end server, because it shows that the HTTPs is down, which brings my nodes down, the back end servers are configured with the redirect to https, they accept https only. When this error occurs the VIP 10.0.0.70 is also down.
    • jaikumar_f5's avatar
      jaikumar_f5
      Icon for Noctilucent rankNoctilucent
      Are you saying that you have not applied any monitor for your pool members. Please share your existing setup masking the imp details.
      tmsh list ltm virtual <virtual name>
      tmsh list ltm pool <pool name>
        KhubaibArshad
        root@f5-35(Active)(tmos)# list ltm virtual vns-portal-vip
        ltm virtual vns-portal-vip {
          destination 10.10.10.70:any
          ip-protocol tcp
          mask 255.255.255.255
          pool VNS-Portal-Pool
          profiles {
            fastL4 { }
          snatpool vns-snat-pool
          translate-port disabled
        root@f5-35(Active)(tmos)# list ltm pool VNS-Portal-Pool
        ltm pool VNS-Portal-Pool {
          members {
            10.10.10.71:smtp {
              session monitor-enabled
            10.10.10.71:domain {
            10.10.10.71:http {
            10.10.10.71:https {
            10.10.10.71:smtps {
            10.10.10.71:submission {
            10.10.10.72:smtp {
            10.10.10.72:domain {
            10.10.10.72:http {
            10.10.10.72:https {
            10.10.10.72:smtps {
            10.10.10.72:submission {
            10.10.10.73:smtp {
            10.10.10.73:domain {
            10.10.10.73:http {
            10.10.10.73:https {
              monitor none
            10.10.10.73:smtps {
            10.10.10.73:submission {
          monitor tcp and https_443
  • M_2's avatar
    M_2
    You cannot add different service ports to a single pool .
    seems you have created a VIP with * ports , it should have some irule logic attached to redirect SMTP traffic to SMTP pool , HTTP traffc to HTTP pool and so on ....
