Sly_85819's avatar
Sly_85819
Oct 13, 2009
SSL pass-through configuration
Can someone tell me how to I configure SSL pass-through for Standard VS? Basically we dont want to have SSL offloading on LTM and the server should have SSL cert. I have used 2 options suggested by F5 support, 1) Configure serverssl profile as Server SSL Profile and 2) Configure none for Client and Server profile settings. The first option worked only once for us and then never worked for any other VS. The second option didnt work either.
The only way it worked is with Performance L4 type VS. I am wondering if anyone has successfully configured ssl pass-through with Standard VS.
