Ruudje_121125's avatar
Ruudje_121125
Aug 08, 2013
SSL Offloading + X-Forwarding + Cookie persistence
Hi all,
I have a BIGIP LTM 1600 with software version 11.3
For the virtual server (for the use of Blackboard and ELEUM) we have some issues. Clients who have an open session get session errors when they get a different IP address when they move around.
The support team of BlackBoard advices to use cookie based persistence with x-forwarding. Unfortunately they haven't got a manual for the F5.
Correct me if i'm wrong, when i want to use cookie persistence i need to do SSL offloading due the fact that the VIP and REAL Servers use HTTPS.
This is what i tried:
Configured a Client SSL Profile, created a HTTP profile with Redirect Rewrite All and Insert X-Forwarded-For enabled. Results in TOO_MANY_REDIRECTS
Tried to use an iRule instead of the HTTP profile
HTTP::header insert "X-Forwarded-Proto" "https";
Results in a connection time out
I haven't tried to insert a cookie yet.
How can i check if the SSL offload is correct?
What do i need to change on the server side?
How to insert Cookies?
Thanks in advance for reading and help!
Regards,
Ruud
  • when i want to use cookie persistence i need to do SSL offloading due the fact that the VIP and REAL Servers use HTTPS.yes
    Configured a Client SSL Profile, created a HTTP profile with Redirect Rewrite All and Insert X-Forwarded-For enabled. Results in TOO_MANY_REDIRECTScan you try clientssl, serverssl, http profiles with x-forwarded-for and cookie persistence?
    e.g.
    root@(ve11a)(cfg-sync Changes Pending)(Active)(/Common)(tmos) list ltm virtual bar
    ltm virtual bar {
        destination 172.28.20.111:443
        ip-protocol tcp
        mask 255.255.255.255
        persist {
            cookie {
                default yes
        pool foo
        profiles {
            clientssl {
                context clientside
            myhttp { }
            serverssl {
                context serverside
            tcp { }
        source 0.0.0.0/0
        source-address-translation {
            type automap
        vs-index 6
    root@(ve11a)(cfg-sync Changes Pending)(Active)(/Common)(tmos) list ltm profile http myhttp
    ltm profile http myhttp {
        app-service none
        defaults-from http
        insert-xforwarded-for enabled
    root@(ve11a)(cfg-sync Changes Pending)(Active)(/Common)(tmos) list ltm pool foo
    ltm pool foo {
        members {
            200.200.200.101:443 {
                address 200.200.200.101
     test
    [root@ve11a:Active:Changes Pending] config  curl -Ik https://172.28.20.111
    HTTP/1.1 200 OK
    Date: Thu, 08 Aug 2013 09:33:07 GMT
    Server: Apache/2.2.3 (CentOS)
    Last-Modified: Thu, 23 May 2013 00:28:46 GMT
    ETag: "4185a8-59-c3efab80"
    Accept-Ranges: bytes
    Content-Length: 89
    Content-Type: text/html; charset=UTF-8
    Set-Cookie: BIGipServerfoo=1707657416.47873.0000; path=/
  • There's actually a few things going here I think.
    1. Users are getting moved around between servers because you don't have any kind of persistence enabled. The cookie-based persistence recommendation is actually a good one. Simply apply it in the virtual server properties and the client will receive a cookie that indicates the first chosen pool member.
    2. Using any kind of layer 7 persistence method (cookie, universal, hash) requires the BIG-IP to be able to SEE the HTTP payload, so you would definitely need to decrypt the traffic with a client SSL profile. Whether you re-encrypt with a server SSL profile is up to you and the server admins, but generally speaking you're going to get a potentially huge performance boost if you leave it unencrypted.
    3. The x-forwarded-proto header is rarely used, if ever, and I can't image Blackboard cares about it either. The x-forwarded-for header, however, is used quite often in situations where the proxy (BIG-IP) must change the client's source address (for internal routing) but the server still needs to be able to see the client's true source. You didn't indicate that you were SNATting, so I don't believe this header is necessary.
    4. The HTTP profile's Redirect Rewrite setting is used when you are NOT re-encryting to a backend server, and that server (because it doesn't realize it's behind an SSL-based proxy) sends redirects to itself using "http://". The setting automatically rewrites these to "https://". If you're re-encrypting to the server, then this setting has no purpose.
    Also, can you elaborate on "TOO_MANY_REDIRECTS"?
  • Thanks for your answers.
    I've got SSL Offloading and cookie insertion working, only not for the intended servers.
    When i use the server pool that uses HTTPS i get the error message in Chrome ERR_TOO_MANY_REDIRECTS
    If i use a different pool that uses HTTP all works fine.
    I configured the HTTP_Profile for this VIP with Redirect Rewrite setting, but with no result.
    For Source Address Translation i use Auto Map
    Is there a way to troubleshoot this?
  • When i use the server pool that uses HTTPS i get the error message in Chrome ERR_TOO_MANY_REDIRECTS can you post the virtual server and pool configuration?
    tmsh list ltm virtual (virtual server name)
    tmsh list ltm pool (pool name)
  • ltm virtual ELEUM-ACCEPTATIE-443 {
    destination x.x.x.x:https
    ip-protocol tcp
    persist {
    ELEUM_COOKIE {
    default yes
    pool ELEUM-ACCEPTATIE
    profiles {
    SSL-ELEUMACCEPT {
    context clientside
    eleum-http { }
    um_lan-optimized_tcp_profile_5400 { }
    wan-optimized-compression { }
    source 0.0.0.0/0
    type automap
    vlans {
    external
    vlans-enabled
    tmsh list ltm pool ELEUM-ACCEPTATIE
    ltm pool ELEUM-ACCEPTATIE {
    members {
    y.y.y.y:https {
    address y.y.y.y
    session monitor-enabled
    state up
    z.z.z.z:https {
    address z.z.z.z
    state up
    monitor um_https_monitor
  • When i use the server pool that uses HTTPS i get the error message in Chrome ERR_TOO_MANY_REDIRECTS when https pool was used, you also added serverssl profile to the virtual server, didn't you?
  • I'm not using serverssl as Kevin mentioned that it would not be necessary and a performance boost
  • What I meant was that if you're NOT re-encrypting to the server (not sending to port 443 pool members), then you don't need a server SSL profile. If you ARE sending to port 443 (SSL) pool members, then you DO need a server SSL profile. This profile is what allows the BIG-IP to establish an SSL session with the back end servers. You would generally see a performance increase if you DO NOT do SSL at all on the application servers - pure port 80 traffic.
  • Ok, clear.
    I need to do ServerSSL to get this to work.
    Thanks both of you for the support!
