David_Pearson_1's avatar
David_Pearson_1
Sep 06, 2018
SSL Certificate Issue
Certificate Issue, I had a message from our certificate authority
"As per Google’s blog post, you will need to replace all certificates which were issued before December 1 2017 by Symantec, Thawte, GeoTrust or RapidSSL in order to avoid browser warnings when Chrome 70 is released. Your impacted certificates are listed below."
I went on their web site and renewed the certs, when I recieved the new ones I realised I had not generated a csr, importing them does not show any keys assigned to the cert, how canI reslove this or do I have to provide a new csr to the cert autority and get new certs.
  • For a CA to simply provide you a new certificate, they'd either have to have a copy of the private key, or would generate a new certificate from the original private key. My guess is they're relying on the original private key, so you'd just need to replace the certificate portion on the BIG-IP from the cert/key pair.
