Nicol4s's avatar
Nicol4s
Sep 02, 2021
sshd could not load host key
Hello,
I'm running a fresh install of BIG IP VE using TMOS 14.1.4.3
The sshd daemon is not able to start because of the following message :
Could not load host key: /config/ssh/ssh_host_rsa_key
When connected using the bash terminal, I can see the content of the key just fine.
I have tried to relabel the filesystem in order to fix the SeLINUX permissions but still no dice.
Procedure that was applied : https://support.f5.com/csp/article/K74412100
thank you.
  • Hello Nicol4s.
    You just need to recreate your SSH RSA key.
    ssh-keygen -t rsa -f /config/ssh/ssh_host_rsa_key
    systemctl restart sshd
    Let me know if it works in your case.
    Regards,
    Dario.
  • Hello Dario,
    I did something very similar to your solution :
    KB Reference used : https://support.f5.com/csp/article/K66144802
    bigstart stop sshd
    restorecon -rF /config/ssh/ssh_host_*
    bigstart restart sshd
    journalctl -u sshd
    Now the SSH daemon is able to start correctly when my VM boot or reboot.
    Thank you for the tip.
    Regards.
