patonbike's avatar
patonbike
Icon for Cirrus rankCirrus
7 years ago
SQL Monitor question / problem...
Is it possible to run a SQL query and depending on the result put a pool member up or down? The problem here is that the SQL query is not running against the pool member.
  • Yes. Both the MSSQL and MySQL monitors have fields where you can put an alias address (the address of the SQL server you want to check) and depending on whether the check is successful or not your pool member(s) will be marked UP/DOWN.
