patonbike_25784
Aug 09, 2018SQL Monitor question / problem...
Is it possible to run a SQL query and depending on the result put a pool member up or down? The problem here is that the SQL query is not running against the pool member.
Ryannnnnnnnn
Altocumulus
Aug 09, 2018Yes. Both the MSSQL and MySQL monitors have fields where you can put an alias address (the address of the SQL server you want to check) and depending on whether the check is successful or not your pool member(s) will be marked UP/DOWN.
patonbike
Cirrus
Aug 10, 2018Thank you - I see those fields, but I don't have the ability to modify the field at least not from the monitor page. It just says :
All Addresses
- All Ports
