sol11438: Creating SSL SAN certificates and CSRs using OpenSSL
I have a certificate problem where F5 does not include the SAN extension in the generated CSR. See the following doc for details sol13770: The BIG-IP system fails to include the Subject Alternative Name extension while generating a CSR.
The workaround is to use OpenSSL to generate the CSR, see (sol11438). The problem is that I receive the following error for key mismatch when I try to import the certificate signed by CA. Is there away to tell F5 where to look for the private key under /var/tmp/mySSL/www.example.com.key?
01070313:3: Error reading key PEM file /config/filestore/files_d/Common_d/certificate_key_d/:Common:example.com.key_15190_1 for profile /Common/example.com: error:0B080074:x509 certificate routines:X509_check_private_key:key values mismatch
- mimlo_61970
Cumulonimbus
You should just need to import the key first. In the web ui, under certificates, do an import, Import type is key, give it a name and then paste/upload the key. You will then see the key in the certificate list. Click it and choose import under the certificate tab, and again paste/upload the certificate.
- wonned_165453
Issue resolved, thank you !
