Vincent_Malguy_'s avatar
Vincent_Malguy_
Oct 11, 2007
snmp pool monitoring
I am playing with snmp inside a perl script. Thank for the file MIB_deconstructed that help a lot.
Still, I have some questions :
1-Does someone have a perl fonction to print the ip in hexa format (for exemple , the result of the iod .1.3.6.1.4.1.3375.2.2.10.1.2.1.3.4.86.73.80.49
2-Does someone have a perl function/table to print in humanreadable what is return in the ltmPoolLBMode (iod : .1.3.6.1.4.1.3375.2.2.5.1.2.1.2.10.116.101.115.116.95.114.97.116.105.111
3-Does someone have "a way" to get the member that are inside a pool ?
Regards,
F5 PC certified,
Vincent.
  • the first question is anwsered :
    @IP = split "", $polled_oids->{$vs_ip};
    print hex ($IP[2].$IP[3]).".".hex ($IP[4].$IP[5]).".".hex ($IP[6].$IP[7]).".".hex ($IP[8].$IP[9]);
  • Deb_Allen_18's avatar
    Deb_Allen_18
    Historic F5 Account
    for 1 & 2:
    I think what you are looking for here is "snmptranslate" which is one of the utilities included with the snmp distribution. See Jeff's first comment at the end of the SNMP MIB article for a few more details: Click here
    Pool members roll up under the pool OID, will look it up & post back when I get back to a workstation w/Excel.
    HTH
    /deb
