Brian_Saunders1's avatar
Brian_Saunders1
Apr 02, 2012
SNMP Polling CPU vs. Web GUI CPU Stats
Hey All,
Trying to get the most accurate CPU information via SNMP polling on our F5 LTMs. Currently I am using the following OID string to get the CPU stats on our F5:
sysGlobalHostCpuUsageRatio5m (.1.3.6.1.4.1.3375.2.1.1.2.20.37)
The value that this returns seems to be a bit different than what the Web GUI shows or if I run the "shw sys cpu default" tmsh command.
Here are the current values: SNMP - 18% utilization / Show Sys CPU default: 24%
Even if I check at the other intervals (5sec or 1min) via SNMP it still does not sync up with what the system is showing.
Anyone have any suggestions?
Cheers,
Brian
