Paul_Hamm_71864's avatar
Paul_Hamm_71864
Dec 07, 2007
SNMP Issue
I've been trying to graph SNMP data from our BigIP units running version 'BIG-IP 9.1.1 Build 54.6'. Some of data I am trying to are:
sysStatClientPktsIn
sysStatClientBytesIn
sysStatClientPktsOut
sysStatClientBytesOut
sysStatClientMaxConns
sysStatClientTotConns
sysStatClientCurConns
sysStatServerPktsIn
sysStatServerBytesIn
sysStatServerPktsOut
sysStatServerBytesOut
sysStatServerMaxConns
sysStatServerTotConns
sysStatServerCurConn
However, when I do an snmpwalk against the BigIP no results are returned for these. Ideally, I'd like to graph the same performance stats as available in the GUI performance tool but do it over a longer time frame. In particular, I'm looking for the active connections, new connections and throughput. I'd like to get those globally and on a per virtual server basis as well.
Thanks for you help
  • Deb_Allen_18's avatar
    Deb_Allen_18
    Historic F5 Account
    When you say "no results are returned", do you mean that you don't see anything returned, or the counter values are all reported as 0?
    In any case, here is the scoop on calculating some of the system-wide stats:
    Collecting data on active connections (Click here)
    Collecting data on new connections (Click here)
    Collecting data on throughput (Click here)
    To get the stats per virtual server, you'll have to dig into this branch to find the OIDs for each VS you're interested in:
      .1.3.6.1.4.1.3375.2.2.10.2
      .iso.org.dod.internet.private.enterprises.f5.bigipTrafficMgmt.bigipLocalTM.ltmVirtualServers.ltmVirtualServStat
      F5-BIGIP-LOCAL-MIB::ltmVirtualServStat
    These docs might be helpful in finding the data you want:
    SNMP: LTM v9.x MIB Navigation (Click here)
    SNMP: Capturing SSL Statistics per Virtual Server (Click here)
    HTH
    /deb
