snmp data wrong on standby machine
I have a pool with two members, it works flawlessly
snmp tells me on the Standby Machine that the pool have four members but there are only two members in real On the active machine snmp tells me the correct number of pool members.
- nitass
Employee
have you tried to run snmpget/snmpwalk on standby unit? did it return four?
if so, can you try to restart snmpd?
root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) restart sys service snmpd - cleggewie_11556
Yes it return four
i did tmsh restart sys service snmpd now with new PID
but the answer is the same always 4 members
this is the answer: conn_queue_svcd_per_sec=0.00;;;; conn_queue_all_svcd_per_sec=0.00;;;; total_requests_per_sec=0.00;;;; active_members=2.000000;;;; pool_members=4.000000;;;; connq_depth=0.000000;;;; connq_age_head=0.000000;;;; connq_age_max=0.000000;;;; connq_age_ema=0.000000;;;; connq_age_edm=0.000000;;;; connq_all_depth=0.000000;;;; connq_all_age_head=0.000000;;;; connq_all_age_max=0.000000;;;; connq_all_age_ema=0.000000;;;; connq_all_age_edm=0.000000;;;; curr_sessions=0.000000;;;;
- nitass
Employee
may i have the oid?
- cleggewie_11556
.1.3.6.1.4.1.3375.2.2.5.3.2.1.1.20.47.67.111.109.109.111.110.47.112.111.111.108.95.78.65.83.84.69.83.84.20.47.67.111.109.109.111.110.47.78.79.67.49.86.84.45.86.80.82.48.50.8181
- nitass
Employee
is the oid correct? shouldn't it be F5-BIGIP-LOCAL-MIB::ltmPoolMemberNumber?
anyway, i think F5-BIGIP-LOCAL-MIB::ltmPoolMemberNumber is number of all the pool members.
e.g.
[root@ve11a:Active:In Sync] config snmptranslate .1.3.6.1.4.1.3375.2.2.5.3.2.1.1.20.47.67.111.109.109.111.110.47.112.111.111.108.95.78.65.83.84.69.83.84.20.47.67.111.109.109.111.110.47.78.79.67.49.86.84.45.86.80.82.48.50.8181 F5-BIGIP-LOCAL-MIB::ltmPoolMemberPoolName."/Common/pool_NASTEST"."/Common/NOC1VT-VPR02".8181 [root@ve11a:Active:In Sync] config snmpwalk -v 2c -c public localhost F5-BIGIP-LOCAL-MIB::ltmPoolMemberNumber F5-BIGIP-LOCAL-MIB::ltmPoolMemberNumber.0 = INTEGER: 4 [root@ve11a:Active:In Sync] config grep -A 7 ltmPoolMemberNumber\ OBJECT-TYPE /var/tmp/mibs_f5/F5-BIGIP-LOCAL-MIB.txt ltmPoolMemberNumber OBJECT-TYPE SYNTAX INTEGER MAX-ACCESS read-only STATUS current DESCRIPTION "The number of ltmPoolMember entries in the table." ::= { ltmPoolMember 1 } [root@ve11a:Active:In Sync] config tmsh list ltm pool ltm pool foo { members { 200.200.200.101:80 { address 200.200.200.101 } 200.200.200.111:80 { address 200.200.200.111 } } } ltm pool foo3868 { members { 200.200.200.101:3868 { address 200.200.200.101 } } } ltm pool loghost { members { 172.28.24.1:514 { address 172.28.24.1 } } } - cleggewie_11556
xxxxx:/S1-green-P:Standby:In Sync] ~ snmpwalk -v 2c -c xxxxxx 1x.x.x.x ltmPoolMember | grep NASTEST F5-BIGIP-LOCAL-MIB::ltmPoolMemberPoolName."/Common/pool_NASTEST"."/Common/NOC1VT-VPR01".8181 = STRING: /Common/pool_NASTEST F5-BIGIP-LOCAL-MIB::ltmPoolMemberPoolName."/Common/pool_NASTEST"."/Common/NOC1VT-VPR02".8181 = STRING: /Common/pool_NASTEST F5-BIGIP-LOCAL-MIB::ltmPoolMemberAddrType."/Common/pool_NASTEST"."/Common/NOC1VT-VPR01".8181 = INTEGER: ipv4(1) F5-BIGIP-LOCAL-MIB::ltmPoolMemberAddrType."/Common/pool_NASTEST"."/Common/NOC1VT-VPR02".8181 = INTEGER: ipv4(1) F5-BIGIP-LOCAL-MIB::ltmPoolMemberAddr."/Common/pool_NASTEST"."/Common/NOC1VT-VPR01".8181 = Hex-STRING: AC 14 0C 69 F5-BIGIP-LOCAL-MIB::ltmPoolMemberAddr."/Common/pool_NASTEST"."/Common/NOC1VT-VPR02".8181 = Hex-STRING: AC 14 0C 6A F5-BIGIP-LOCAL-MIB::ltmPoolMemberPort."/Common/pool_NASTEST"."/Common/NOC1VT-VPR01".8181 = Gauge32: 8181 F5-BIGIP-LOCAL-MIB::ltmPoolMemberPort."/Common/pool_NASTEST"."/Common/NOC1VT-VPR02".8181 = Gauge32: 8181 F5-BIGIP-LOCAL-MIB::ltmPoolMemberConnLimit."/Common/pool_NASTEST"."/Common/NOC1VT-VPR01".8181 = INTEGER: 0 F5-BIGIP-LOCAL-MIB::ltmPoolMemberConnLimit."/Common/pool_NASTEST"."/Common/NOC1VT-VPR02".8181 = INTEGER: 0 F5-BIGIP-LOCAL-MIB::ltmPoolMemberRatio."/Common/pool_NASTEST"."/Common/NOC1VT-VPR01".8181 = INTEGER: 1 F5-BIGIP-LOCAL-MIB::ltmPoolMemberRatio."/Common/pool_NASTEST"."/Common/NOC1VT-VPR02".8181 = INTEGER: 1 F5-BIGIP-LOCAL-MIB::ltmPoolMemberWeight."/Common/pool_NASTEST"."/Common/NOC1VT-VPR01".8181 = INTEGER: 0 F5-BIGIP-LOCAL-MIB::ltmPoolMemberWeight."/Common/pool_NASTEST"."/Common/NOC1VT-VPR02".8181 = INTEGER: 0 F5-BIGIP-LOCAL-MIB::ltmPoolMemberPriority."/Common/pool_NASTEST"."/Common/NOC1VT-VPR01".8181 = INTEGER: 0 F5-BIGIP-LOCAL-MIB::ltmPoolMemberPriority."/Common/pool_NASTEST"."/Common/NOC1VT-VPR02".8181 = INTEGER: 0 F5-BIGIP-LOCAL-MIB::ltmPoolMemberDynamicRatio."/Common/pool_NASTEST"."/Common/NOC1VT-VPR01".8181 = INTEGER: 1 F5-BIGIP-LOCAL-MIB::ltmPoolMemberDynamicRatio."/Common/pool_NASTEST"."/Common/NOC1VT-VPR02".8181 = INTEGER: 1 F5-BIGIP-LOCAL-MIB::ltmPoolMemberMonitorState."/Common/pool_NASTEST"."/Common/NOC1VT-VPR01".8181 = INTEGER: up(4) F5-BIGIP-LOCAL-MIB::ltmPoolMemberMonitorState."/Common/pool_NASTEST"."/Common/NOC1VT-VPR02".8181 = INTEGER: up(4) F5-BIGIP-LOCAL-MIB::ltmPoolMemberMonitorStatus."/Common/pool_NASTEST"."/Common/NOC1VT-VPR01".8181 = INTEGER: up(4) F5-BIGIP-LOCAL-MIB::ltmPoolMemberMonitorStatus."/Common/pool_NASTEST"."/Common/NOC1VT-VPR02".8181 = INTEGER: up(4) F5-BIGIP-LOCAL-MIB::ltmPoolMemberNewSessionEnable."/Common/pool_NASTEST"."/Common/NOC1VT-VPR01".8181 = INTEGER: 0 F5-BIGIP-LOCAL-MIB::ltmPoolMemberNewSessionEnable."/Common/pool_NASTEST"."/Common/NOC1VT-VPR02".8181 = INTEGER: 0 F5-BIGIP-LOCAL-MIB::ltmPoolMemberSessionStatus."/Common/pool_NASTEST"."/Common/NOC1VT-VPR01".8181 = INTEGER: enabled(1) F5-BIGIP-LOCAL-MIB::ltmPoolMemberSessionStatus."/Common/pool_NASTEST"."/Common/NOC1VT-VPR02".8181 = INTEGER: enabled(1) F5-BIGIP-LOCAL-MIB::ltmPoolMemberMonitorRule."/Common/pool_NASTEST"."/Common/NOC1VT-VPR01".8181 = STRING: F5-BIGIP-LOCAL-MIB::ltmPoolMemberMonitorRule."/Common/pool_NASTEST"."/Common/NOC1VT-VPR02".8181 = STRING: F5-BIGIP-LOCAL-MIB::ltmPoolMemberAvailabilityState."/Common/pool_NASTEST"."/Common/NOC1VT-VPR01".8181 = INTEGER: none(0) F5-BIGIP-LOCAL-MIB::ltmPoolMemberAvailabilityState."/Common/pool_NASTEST"."/Common/NOC1VT-VPR02".8181 = INTEGER: none(0) F5-BIGIP-LOCAL-MIB::ltmPoolMemberEnabledState."/Common/pool_NASTEST"."/Common/NOC1VT-VPR01".8181 = INTEGER: none(0) F5-BIGIP-LOCAL-MIB::ltmPoolMemberEnabledState."/Common/pool_NASTEST"."/Common/NOC1VT-VPR02".8181 = INTEGER: none(0) F5-BIGIP-LOCAL-MIB::ltmPoolMemberDisabledParentType."/Common/pool_NASTEST"."/Common/NOC1VT-VPR01".8181 = INTEGER: 0 F5-BIGIP-LOCAL-MIB::ltmPoolMemberDisabledParentType."/Common/pool_NASTEST"."/Common/NOC1VT-VPR02".8181 = INTEGER: 0 F5-BIGIP-LOCAL-MIB::ltmPoolMemberStatusReason."/Common/pool_NASTEST"."/Common/NOC1VT-VPR01".8181 = STRING: F5-BIGIP-LOCAL-MIB::ltmPoolMemberStatusReason."/Common/pool_NASTEST"."/Common/NOC1VT-VPR02".8181 = STRING: F5-BIGIP-LOCAL-MIB::ltmPoolMemberNodeName."/Common/pool_NASTEST"."/Common/NOC1VT-VPR01".8181 = STRING: /Common/NOC1VT-VPR01 F5-BIGIP-LOCAL-MIB::ltmPoolMemberNodeName."/Common/pool_NASTEST"."/Common/NOC1VT-VPR02".8181 = STRING: /Common/NOC1VT-VPR02 xxxxx:/S1-green-P:Standby:In Sync] ~ tmsh list ltm pool xxxxx:/S1-green-P:Standby:In Sync] ~ ltm pool pool_NASTEST { members { NOC1VT-VPR01:8181 { address 172.20.12.105 session monitor-enabled state up } NOC1VT-VPR02:8181 { address 172.20.12.106 session monitor-enabled state up } } monitor tcp_8181 }- nitass
Employee
where does it report four members?
- cleggewie_11556
now it reports correct and i don't know why
The OID .1.3.6.1.4.1.3375.2.2.5.3.1.0 reports 41 Pool Members and 41 are correct
A multiple sync to the Standby System has resolve the Problem.
