smandru_360193's avatar
smandru_360193
May 01, 2018
SNAT Error While Using Ansible to Create a VS in BigIP
I am trying to create a VS using Ansible playbook. It is able to create the virtual server but not able to set SNAT setting that i wanted (Automap), getting the following error
fatal: [xxx.com]: FAILED! => {"changed": false, "failed": true, "msg": "received exception: Error on setting snat : Method not found: 'LocalLB.VirtualServer.LocalLB.VirtualServerPort.get_source_address_translation_type'"}
Version details:
  • Ansible: 2.3.0.0
  • python: 2.7.5
  • BigIP: 11.12.1
this is how my playbook looks
name: Create virtual server
 bigip_virtual_server:
   server: xxx.com
   user: admin
   password: MYPASS
   state: present
   destination: DEST_IP
   port: 80
   pool: POOL_NAME
   all_profiles:
     - tcp
     - http
   snat: Automap
   validate_certs: no
Any support on this would be really appreciated. Thanks!
  • Hello,
    You have to use "source-address-translation" instead snat and set it to "type automap". It will work.
    I advise you for the future to test your parameter trough tmsh:
    tmsh modify ltm virtual vs-name source-address-translation { type automap }
    Regards,
  • can you try following the procedure in this url: http://clouddocs.f5.com/training/community/gsts/html/class1/module2/lab05.html
    I noticed that on the reference url, snat is defined higher up the list compare to yours, its in the bottom.
    can you try modifying your playbook and somewhat copy what is in the reference url? share any errors when you run the playbook after the change.
    when running your playbook, since you are getting an error, can you enable verbose logging and share the output? see this url:
    http://clouddocs.f5.com/training/community/gsts/html/class1/module4/module4.html
    hopefully, this will give more verbose output on the errors received.
    see also http://clouddocs.f5.com/products/orchestration/ansible/devel/modules/bigip_virtual_server_module.htmlbigip-virtual-server
    • smandru_360193's avatar
      smandru_360193
      I had interchanged the modules/arguments to the way it is showed in the reference url, but had no luck, i got the same error
          password: MY_PASS
          pool: POOL_NAME
          port: 80
          server: xxx.com
          snat: Automap
          user: admin
          all_profiles:
            - tcp
            - http
          validate_certs: no
      error
      fatal: [xxx.com]: FAILED! => {"changed": false, "failed": true, "msg": "received exception: Error on updating Virtual Server : Error on setting snat : Method not found: 'LocalLB.VirtualServer.LocalLB.VirtualServerPort.get_source_address_translation_type'"}
      I had the same job run it in verbose mode and this is the output i got
      TASK [Create virtual server] *********************************************************************************************************************
      task path: /etc/ansible/f5-virt.yml:6
      Using module file /usr/lib/python2.7/site-packages/ansible/modules/network/f5/bigip_virtual_server.py
       ESTABLISH LOCAL CONNECTION FOR USER: root
       EXEC /bin/sh -c 'echo ~ && sleep 0'
       EXEC /bin/sh -c '( umask 77 && mkdir -p "` echo /root/.ansible/tmp/ansible-tmp-1525440236.15-140334385587090 `" && echo ansible-tmp-1525440236.15-140334385587090="` echo /root/.ansible/tmp/ansible-tmp-1525440236.15-140334385587090 `" ) && sleep 0'
       PUT /tmp/tmpfOasSB TO /root/.ansible/tmp/ansible-tmp-1525440236.15-140334385587090/bigip_virtual_server.py
       EXEC /bin/sh -c 'chmod u+x /root/.ansible/tmp/ansible-tmp-1525440236.15-140334385587090/ /root/.ansible/tmp/ansible-tmp-1525440236.15-140334385587090/bigip_virtual_server.py && sleep 0'
       EXEC /bin/sh -c '/usr/bin/python /root/.ansible/tmp/ansible-tmp-1525440236.15-140334385587090/bigip_virtual_server.py; rm -rf "/root/.ansible/tmp/ansible-tmp-1525440236.15-140334385587090/" > /dev/null 2>&1 && sleep 0'
          "changed": false,
          "failed": true,
          "invocation": {
              "module_args": {
                  "all_policies": null,
                  "all_profiles": [
                      "tcp",
                      "http"
                  "all_rules": null,
                  "default_persistence_profile": null,
                  "description": null,
                  "destination": "DEST_IP",
                  "enabled_vlans": null,
                  "fallback_persistence_profile": null,
                  "name": "VS_NAME",
                  "partition": "Common",
                  "password": "VALUE_SPECIFIED_IN_NO_LOG_PARAMETER",
                  "pool": "POOL_NAME",
                  "port": "80",
                  "route_advertisement_state": null,
                  "server": "xxx.com",
                  "server_port": 443,
                  "snat": "Automap",
                  "state": "present",
                  "user": "admin",
                  "validate_certs": false
      Thanks for all your time to support this!
  • @anonymous007
    The version of BIG-IP you're using is to old. In other words "Plan your upgrade path".
    11.12.1 is not an actual version, so I assume you meant 11.2.1. In that case, this method (get_source_address_translation_type) was not introduced until 11.3.0.
    So...basically...you're out of luck.
    You can use the bigip_command module in CLI mode for BIG-IP versions earlier than 12.x. However, the real solution as I said earlier, is to plan your upgrade.
