shawmcbigdis_84's avatar
shawmcbigdis_84
Feb 24, 2010
SNAT Automap iRule not working after ver 10.1 upgrade
After we upgraded our LTM's from 9.4 to 10.1 I realized our SNAT rule wasn't working. Because of our network layout the LTM is the default gateway for our servers, so we need it to SNAT when they are trying to access the internet, but not when they are accessing the rest of the network. So I use this iRule;
when CLIENT_ACCEPTED {
Compare destination address with the pre-defined
class of RFC1918 non-routable addresses
If not in that group, automap-SNAT the connection
if {not [matchclass [IP::local_addr] equals ::private_net] } {
log local0.info "intenet access attempted"
snat automap
IN ver 9.4 it worked fine. Now when I enable to the log line I get the following error in the log
Feb 24 09:33:52 local/tmm err tmm[6881]: 01220001:3: TCL error: outboundSNAT - Invalid matchclass operands - no class or list type found, lhs: ip, rhs: ::private_net (line 5) invoked from within "matchclass [IP::local_addr] equals ::private_net"
The private_net group exists in the Data Group List, so what am I missing here? I am not a developer, so pretty much all my iRules are just cut and pasted together from what I find on this site, so I'm sure it's something simple, just confused as to why it worked in ver 9 and not now.
  • Try simply removing the "::" from the ::private_net references.
    -Matt
  • That did it, thanks! :D
    Now, so I learn from this. Why did I have to remove that?
  • hoolio's avatar
    hoolio
    Hi Shawn,
    This page explains the change to datagroup references in 9.4.4+:
    http://devcentral.f5.com/wiki/default.aspx/iRules/CMPCompatibility.html
    as of 9.4.4, "::" prefix no longer required to reference classes using matchclass or findclass. Classes are static, no need to treat as global, thus CMP compatible.
    This was further reinforced in 10.x. Now you cannot reference classes with $:: or ::. Before you could but it would prevent the use of CMP for the VIP the iRule was on.
    Aaron
