Daya's avatar
Daya
Feb 20, 2020
SMB monitor failure on LTM
I am trying to monitor the file on the pool members and tried using the default SMB monitor template, however this doesn't seem to work . The version I have is 12.1.3
is there a document on how to troubleshoot the SMB monitor failure issues
  • Hi Daya,
    First, you can enable the monitor Logging option to allow the system to log more information about your monitor (BIG-IP system store the log in /var/log/monitors) and thus identify the monitoring issue.
    REF : Enabling monitor logging for a pool member
    Regards
