CraigM_17826
Altocumulus
Sep 15, 2008Small bug with iRule editor 0.9.1.5
Just to let the developers know that I just came across a very minor bug with the iRule editor. The editor fails to display empty iRules, so even though you can see the iRule via the web admin interface that same iRule is not visable via the editor. As soon as you put 1 char in the iRule and save it then the iRule editor will display the iRule in it's list. Not a biggy, but thought I would mention it.
Craig
- Thanks for the feedback Craig!
I vaguely remember not displaying empty iRules in the tree view due to an error when trying to save an empty iRule in the API. I'll have to test that out again and give it a shot.
Just for my reference, what is the use case for having empty iRules in your configuration? I can't personally think of any reason why you would want to B-).
-Joe
