satish_txt_2254
Cirrus
May 22, 2017SIP monitor custom FROM header
In current SIP monitor, it send OPTION packet with
sip:[email protected].. can i change it to use meaningful like sip:[email protected]?
U 10.5.16.62:50410 -> 10.5.16.21:5060
OPTIONS sip:10.5.16.21:5060 SIP/2.0.
Call-ID: [email protected].
CSeq: 1495473005 OPTIONS.
Via: SIP/2.0/UDP 10.5.16.62:50410;rport;branch=z9hG4bKf5s1pA6DlB84v.
Via: SIP/2.0/UDP f5-1-mgmt.foo.com:5060;branch=z9hG4bK2ca81a62.
Max-Forwards: 1.
To: sip:10.5.16.21.
Accept: application/sdp.
Content-Length: 0.
In SIP advance config there is an option called SIP header: but no idea how to use and what to put there tried some option but didn't help.
Hi Satish, I am not sure how to change the user part of From header but the domain part is nothing but the hostname of F5. Change the hostname of F5 the same will get reflected in domain part of From header in SIP OPTIONS. Thanks Syed Nazir
- Nazir_52641
Cirrus
