Leslie_South_55
Sep 25, 2007Simple pool selection using URI not so simple...
Greetings once again, I am trying to select a pool based on content in the URI; what I am seeing is the first request selects the pool correctly, but requests that follow are using the default pool.
VS with cookie insert persistence
default pool defined in the VS resource
rule looks like this
if { [HTTP::uri] contains "en_CA" } {
use pool pool_cananda
log local0. "Canada request - canada pool"
else { use pool pool_us }
log local0. "using default pool"
}here are some log entries
Sep 25 12:13:39 tmm tmm[1055]: Rule rule_test-can_redirect : using default pool
Sep 25 12:17:46 tmm tmm[1055]: Rule rule_test-can_redirect : Canada request - canada pool
Sep 25 12:17:46 tmm tmm[1055]: Rule rule_test-can_redirect : using default pool
Sep 25 12:17:50 tmm tmm[1055]: Rule rule_test-can_redirect : Canada request - canada pool
Sep 25 12:17:50 tmm tmm[1055]: Rule rule_test-can_redirect : using default pool
Sep 25 12:17:57 tmm tmm[1055]: Rule rule_test-can_redirect : Canada request - canada pool
Sep 25 12:17:57 tmm tmm[1055]: Rule rule_test-can_redirect : using default pool
What am I missing?
-L
- Leslie_South_55
Can anyone provide some insight on this? I'm still stuck.
-L - Andy_Herrman_22
Here's the code you gave, reformatted a bit:when HTTP_REQUEST { if { [HTTP::uri] contains "en_CA" } { use pool pool_cananda log local0. "Canada request - canada pool" } else { use pool pool_us } log local0. "using default pool" }
I think it's just your logging that's off. Notice that your "using default pool" log is outside the else statement, so it will display that every time. Try this:when HTTP_REQUEST { if { [HTTP::uri] contains "en_CA" } { use pool pool_cananda log local0. "Canada request - canada pool" } else { use pool pool_us log local0. "using default pool" } }
and see if it changes. - Leslie_South_55
we can mark this one in the "DOOHH" category; it turns out that I had another rule that I use to trasfert HTTP to HTTPS and in that rule, there was an 'else pool pool_us" statement. This was causing the traffic to be sent to the US pool, once I removed it, it redirects correctly.
Thanks for the eyes on this, guess I just need to slow down.
-L
